January 24, 200917 yr comment_310801 Hi guys. I own a 1978 Ke55 Rolla. I'm just wondering where the hose goes that comes from the bottom of the fuel canister (charcoal canister what ever it is called) just behind the battery. I'm only asking because mine is loose and i can pull it out easy. The hose comes from the bottom of the canister and just sits in the chassis rail below it, under the battery. Cheers Andrew Report
January 24, 200917 yr comment_310845 That's where it goes, maybe it should have a rubber grommet in the chassis rail for the pipe to sit tight in the hole. :) Report
