Hey in the middle of a build-up. 4age SP, 7 rib block
I have done all the main caps/bearings etc.
While checking the normal thrust clearance (Sideways) it's perfect very little movement 0.015-0.020.
But while spinning the crank over I notice the thrust bearing itself slightly moving up and down and across, Not (sideways) am I making any sence?? :jamie:
Is this a problem?? Measures up identical to old set and no machining been done just a crank linish.
Any ideas???????????????
Anyone :yes:
