August 18, 200917 yr comment_367026 hi guys... just wondering if there is a trick or something to get these gear box's out... have all the bolts removed but it just wont come out ... so i have chucked a bolt in and a jack stand under to keep it up. can anyone help ? things i might be thinking are dropping the sub frame or removing the swaybar. Cheers nichy Report
August 20, 200917 yr comment_367535 You may need to give more info or pics. When I did box changes on AE82s I used to pop the driveshafts out of the gearbox. Have you managed to split the engine and box? Obviously you have disconnected all the shifter cables, clutch lines, wires etc.? Also check on twincam.org Edited August 20, 200917 yr by machg Report
