1984 S12 Gazelle Ca18det + Heaps More Will Swap
Item Summary: 1984 s12 Gazelle Notch WILL SWAP
Condition: Good
Reason for Selling: Change
Asking Price: 4000
Delivery Methods: PickUp
Contact Info: pm
Extra Information:
standard features:
2-door rear wheel drive coupe
power windows
6-dial dash
digital clock
power mirrors
pop-up headlights
4-link rear end
mod list:
inside:
cd player
300zx Z32 steering wheel
boost gauge
Monza 3-point harness (ADR approved)
engine:
CA18DET JDM
ACL Race series piston rings, rod-end bearings, 1.3mm metal head gasket
permaseal VRS kit
CA20E water pump
CA16DE timing belt
modified oil pump with oil feed restricter in head
tapped rods
S14 T28
exceedy super heavy duity organic clutch
front mounted intercooler
2.5in mandrel bent exaughst
poddy with hectikc cold air intake
Dr. Drift re-tuned ECU
surge tank
VL-turbo external fuel pump
12in thermo fan
thermo fan controller
suspension:
welded h190 diff
16in alloys w 205/55R16's
S13 hubs, brakes and knuckles
S12 tie rod ends
R31 lower control arms and caster rods with R31 ball joints
S13 pro sport coilovers
adjustable camber tops
extended wheel studs on the front
EL Falcon rear short stroe heavy duty shocks
cut VN commodore wagon springs
All gauges work, so tacho now works.
Also has new plugs
runs 14psi on a safe tune
$4000
pm or msg 0437 696 872
Car goes good, does good skids.
perfect ameatuer drift car
can drop off at the boat as i live 15mins away from Devonport.
WILL SWAP
pics wont load for me, can u post again but using the rolla club attachment thingo down there v v v haha thanks
I'm from spreyton so yeh close.
