July 21, 201016 yr comment_453625 FOR SALE: Make / Model / Year: Nissan Skyline R31 1989 Location: St Agnes, Adelaide, SA Kilometers: 100,000 on motor, dash says 350,000 as it's been replaced by last owner Transmission type: Manual Engine: 30e+t Colour: White Modifications: turbo conversion using R33 series 2 turbo, aftermarket T3 manifold, intercooler, 3-inch exhaust, nistune ECU, walbro 255 fuel pump, whiteline swaybars, lowered springs and shocks, headunit, RF amp, 2x12 inch subs, RB20 gearbox (no 5th gear, all other gears shift overrated), 17x8.5 and 17x9.5 Work Modenas, welded diff. Roadworthy Certificate: n/a Registered: Yes Accident History: One incident with a traffic light, has been repaired at home car drives fine. cable tie spec if you know what i mean Price: around 5 grand. Other Comments: f@$king overrated car, photos really don't do it justice. Turbo conversion has been done very neatly, no corners cut, everything is new hoses or braided lines and speedflow fittings. Sits very flat through corners with the suspension setup. Sound system cranks! Made 182rwkw at 8psi when it was dyno tuned. Only drawback to the car is the gearbox has no 5th gear for some reason, but all the other gears shift overrated. Would rather a swap for a clean clean ke70 has to be manual, and cash my way, unless it's 4age or ca18det or something wicked like that :) Could possible come with 400 Gizzmo ms-2 boost controller also depending on what I get for it. SEND SMS to 0466887924 or Facebook me Nick Andrushenko. Cheers pic pic Edited July 21, 201016 yr by andrushenko Report
July 22, 201016 yr comment_453666 your probaly not interested butt swap for overrated as white ke70 with aircon and a locker.. plus 1500 your way? was gonna put my ke on here for about 2500 next week.... Report
July 22, 201016 yr Author comment_453682 send me a pic, but i doubt it. more like 2500-3000 cash my way and i know as well, it's cause i'm a wizrd Report
July 22, 201016 yr comment_453776 any chance of some more pictures? including interior etc? cheers Report
