Hi
I have a ae102 seca
a couple of days ago I noticed a thud in the rear left as the wheel spins. I have swapped the wheel with the front left to see if it was the wheel but made no difference.
Any suggestions on what it could be?
I jacked the rear up and freely spun the wheel and there was no thud, so could it be in the suspesion.
Edited by Ae102 petey
If the repetition of the noise increase with speed then it's most likely the wheel bearing. If it's just a constant repetitive knock the you should check you don't have a koala lodged under the car.
PS: handbrakies don't do the wheel bearings or suspension any good.
Edited by GJM85
