R31 Turbo Manual, Sleeper!
*note this is re-advertise.
hi all, i have a r31 turbo 4 door for sale. its a mad sleeper!
it is an rb30et
it runs absolutely sweet, all turbo gear is hidden on outside so you wont get any hassles from the police!
this car was purchased from an old lady as an auto and she had it for the last 15 years.
work has been done proffesionally by turbotune on south road and ben from Mobile auto Solutions (ex nissan employee)
car has been running on 7 pound, and made 160kw on 7 pound with a few less things done than listed below and slight tune.
easy 200kw on 10 pound!
high mounted to4E a/r.50 front compressor housing and garrett exhaust housing sitting on a stainless manifold all heat wrapped with 45mm external wastegate with 10psi turbosmart spring and custom made stainless dump and 3 inch straight exhaust dumping down before diff but retaining standard looking rear stock double pipe muffler and stock rims with exec. hubbies:blink:
r31 factory 5 speed full manual conversion
custom short shift kit
exedy heavy duty clutch kit
turbo smart boost bleeder
new 10pound turbosmart wastegate spring
fuel pressure regulator
VLT 3TA manual turbo ecu
rb20 270cc red top injectors custom fitted to standard vlt rail
custom /made fitted 600x300x76 FMIC with piping bent at top of cooler with short piping kit going to turbo and throttle body
s15 fuel pump
chrome skull racing gear knob :ph43r:
dished leather drift style steering wheel
full manual leather console surround mod
standard diff fitted with a boss mini-spool
gearbox/diff/engine oils all replaced with quality oils
pivot custom dash mounted bar boost guage
exterior/interior tidied up eg.door trim rip and broken door buttons etc
interior is overrated
this car has had alot of money spent on it!
just had full service and $700 spent on new, quality gaskets put throughout (rocker cover, wastegate (metal shims in the wastegate), exhaust manifold, crank case etc etc.
$5000 (no swaps, unless for a road bike of my interest)
any questions do not hesitate to call
0430541780
located in the south
