80ke70 Posted December 30, 2010 Report Posted December 30, 2010 Hey was having trouble putting my rocker arm assembly together was wondering if anyone has ever done it or has a good technique on how to the motor is the 1.8 3tc. Thanks ahead of time for those who respond. Quote
snot35 Posted January 1, 2011 Report Posted January 1, 2011 Maybe put a post in the TExx Corolla Discussion forum, as that's where all the T motor nuts will be. Also, if you could be a little more specific about the problem then someone mechanically minded will likely chime in. Are you having trouble putting the assembly back on the head, putting the components back on the rocker shaft, etc? Quote
