January 16, 201115 yr comment_495819 Item Summary: Nissan Skyline R32 GTS-T - unfinished project Location: Sydney Condition: Car has some exterior damage on the drivers side door (replacement door will be supplied), damaged door seal on the drivers that requires just to be pulled out, dents on the rear quarter panel from someone delibrately hammering it when i had it parked outside one night. The side skirts on both sides are damaged/cracked and will required to be replaced. There is no chassis damage. Please see the pictures below to get a better idea. Reason for Selling: have lost my job, need the funds Asking Price: $6000 firm, might be open to swaps but at this point in time I would prefer the cash. Delivery Methods: Currently not running only due to the fact that I'm awaiting for braided hoses to be made up for the turbo Contact Info: 0401233113 Extra Information: NSW rego till end of January 2010, "EVL32R" custom plates will be supplied. 97,000k's on the chassis Complete GTS-t interior fitted Genuine Nismo adjustable shocks fitted all round Locked diff new tierod ends Earth wiring kit Factory GTS-t calipers painted in blue VHT enamel paint, brake pads were replaced recently on the rear calipers GTR Fibreglass copy front bar (not pictured) Windows tinted by Martin at Ground Zero tints KKR adjustable castor/tension rods - Brand new! (receipts can be provided) 16x7 Hinodex wheels, (5x114 stud pattern, + 30 offset) fitted with average tyres. White 17" wheels pictured on car are not included in sale. 3" exhaust system front mount intercooler, Microtech LT12 ECU 38mm Tial External wastegate Brass button clutch Tial Blow-off valve Garrett GT35/40 Turbo The RB20DET, re-built motor, had the following work done to it, as stated below: RB20DET Block MACHINE & SERVICE CYLINDER HEAD 3MM STEAL HEAD GASKET FITTED GENUINE NISSAN ENGINE FULL CYLINDER HEAD GASKET KIT FITTED VALVE LIFTERS REPLACED GENUINE NISSAN MANIFOLD GASKET FITTED GENUINE NISSAN OIL SEAL FITTED GENUINE NISSAN ROCKER COVER GASKETS FITTED GENUINE KEY WAY CRANK SHAFT FITTED GENUINE NISSAN TIMING BELT FITTED GENUINE NISSAN CRANK SEAL FITTED RECONDITIONED FRONT CRANK SHAFT PULLEY FITTED GENUINE NISSAN THERMOSTAT FITTED Receipts for the re-build can be provided aswell. Car is not listed as a write-off nor listed under REV's either. No finance is oweing on the car either. Car is currently not running due to the fact that I'm just awaiting for braided hoses to be made up for the turbo, which I should be expect during this week. The car will also require a wheel alignment since I've now replaced the castor rods with aftermarket set. Have alot of spare factory parts that can be provided to the buyer at the request, which includes the factory exhaust, turbo, mainfold, side mount & ecu, which I had kept aside if I ever had intentions of going back to stock during my ownership of this car, but I won't be needing it. The Microtech ecu is currently plugged into factory loom via a plug & play adaptor, so therefore car still retains the factory wiring. Will also supply the factory ecu to the buyer. Would be ideal as either a track or drift car project. I have receipts of up to $13,000 of parts purchased and mechanical work that has been done to this car alone. My loss is your gain! Pics: Please note: no longer has GTS-t front bar fitted (as pictured) but instead will provide a GTR Fibreglass copy front bar (not pictured) And a few pictures below when the car was in its former glory.. Report
