S12 Gazelle
1984 sgl model s12
has power windows
r31 siloulette steering wheel
trx rear end conversion
a extremely rare spirit wing for s12 coupe (only one iv ever seen in my life)
s12 silvia window pillar trims(has a silvia bagde instead of the standard gayzelle bagde)
has an alram and central locking not wired up but still in there lol
the whole rear end of the car is filled with nolathane
tinited rear windows
speco water temp and boost gauge
car doesnt come with a stereo but has speakers
battery installed in the boot
now for the engine
its an s13 sr20 de that has been converted to turbo using a aftermarket stainless steel manifold a t28 turbo and stainless turbo lines
has a BIG blitz fornt mount intercooler which is painted black so its not visible unless your looking for it
has all stainless intercooler piping and silicon joiners
it is a scary fast car can't describe in words having an older car accelerate this is a wierd feeling
also has an s13 clutch master cylinder installed.
bad points
cracked front windsecreen
drivers door trim pretty bad cond. could pick 1 up from upullit cheap 2 match passenger though.
has 2 push start as immobiliser needs 2 b removed or wired up properly i got quoted $50 2 get it removed
gear box is a ca20 box and is a little bit sloppy
chasing $3000 o.n.o
located in Hackham SA
contact 0425765573
thanks adam
