Tham Posted March 21, 2006 Report Posted March 21, 2006 Hi, Does anyone have any spare parts source for a good vacuum advance pump used in the standard contact points distributor in the Corolla KE70'S 4K engine ? My original gave out a couple years ago, so I had to replace it with the "Century" brand OEM unit from Japan. This is the only brand available in Malaysia. They are poorly made and not durable. Firstly, the plastic fine timing adjuster at the end of the spring is not heat resistant - it becomes brittle and disintegrates after a few months, throwing the timing way off. Luckily, my brother-in-law managed to fabricate a copper one as a substitute, and it has been holding out well so far. The rubber diaphragm in the "Century" pump is also not durable. Mine lasted just about a year. Once the diaphragm gives out, the pump does not function anymore. If it gives way again, I'll probably change to a reluctor-type electronic distributor from the salvage yard. I'm currently using contact points with Silicon Chip magazine's high energy ignition unit (Dick Smith kit). Quote
