Tham Posted March 28, 2006 Report Posted March 28, 2006 Does anybody know if the older high energy electronic ignition unit by Silicon Chip magazine (June 1998, kit by Dick Smith) needs to be used with one of those "electronic" coils ? These coils, which usually do not have a ballast resistor, typically come with those stock reluctor-type distributors with built-in ignitors. This is because I have been using the high energy ignition with my Corolla 4K engine's standard coil (with ballast resistor) and I think it is overheating the coil. Several times, I had to pull by the road when the engine began to idle badly, sputtering, kind of like a way-off idle mixture setting. Initially I thought it was the ignition unit's power transistor or IC giving problems, but after cooling down the engine, it appeared to run fine again. I'm using the points to trigger it. I think the standard coil cannot handle the extended dwell set by the ignitor. I've reduced the variable resistor setting (VR1) in the Silicon Chip unit to the mininum, giving 0.25 volts for a coil current of only 4 amps. The coil still runs very hot at this setting, almost burning to the skin. Are those "electronic" coils made to handle extended dwell, or are they different in some other way ? These type of coils can usually be purchased in spare parts shops in Malaysia and are made by "Diamond" of Japan. Quote
