November 10, 201510 yr comment_701367 Folks, Seca for wrecking. Using it as a donor, so the following has gone so far: Engine ECU Loom Gear knob Otherwise everything is there. Car is pretty rough and the interior is mouldy, but if you want anything let me know and I'll provide some details of condition and whether it's worth it. I'm hoping to get it towed over the next few days though, so get in quick! Report
November 11, 201510 yr comment_701385 Hey mate, twin cam has the 4age big port right? I'm after the dizzy, but need to make sure it has the split pin holding the gear in the drive shaft. The smallports had the drive gear pressed on, but I'm pretty certain the ae82 will have the split pin. Is it possible to check this, and check express postage to Melbourne, 3131? I need it asap! Cheers Report
November 11, 201510 yr Author comment_701395 Sorry buddy, the dizzy is part of the engine and I'm using it. It does not have a split pin anyway. Cheers Report
