I'm currently using a 3K Aisan carburetor
on my 4K engine.
This carb doesn't hold idle very well, and
I think it's partly due to the return spring,
which is built into the throttle linkage,
unlike the 4K carb which uses an external
spring hooked to a bracket on the manifold.
I'm thinking of switching back to my previous
4K carb, which has a hot idle compensator,
which is basically a bimetallic strip.
This compensator introduces air into the
intake manifold at higher temperatures and
leans the mixture, and thus gives a smoother
idle too. The currrent 3K carb does not have
this compensator.
However, I undertstand that a lean mixture
makes the engine run even hotter, so I wonder
if that might be a problem.
