Search results
Jump to navigation
Jump to search
Page title matches
- ...) acts like a blow off valve for supercharged engines (As in the case of a 4agze). The ABV acts like a relief valve to reduce boost when not needed. It does There are 2 ways to go about stopping the Air Bypass Valve on a 4agze. Many people do this at the same time as fitting a front mounted intercoole1 KB (219 words) - 13:01, 27 June 2007
Page text matches
- 4AGZE pistons are semi-forged and have ceramic tops. They can be bought new from [[Image:4agze top resized.JPG]]1 KB (206 words) - 05:21, 9 June 2008
- ...ly suggest the N/A version. Though if you want a fast Street/Track car the 4AGZE / 4AGTE option would be the better way to go. The advantage of the Supercha ...ling a CAS (Camshaft Angle Sensor) with coil packs. (These can be found on 4AGZE/20 Valve engines).5 KB (915 words) - 13:27, 17 January 2008
- 4AGZE - Will clear the firewall in a KE70/AE71/AE86 RWD conversion.1 KB (274 words) - 15:32, 27 June 2007
- [[Image:4AGZE Injectors.jpg]]1 KB (150 words) - 08:58, 14 April 2010
- ...ar to the JDM AE86 4AGE rear water outlet and should clear any firewall. A 4AGZE rear water outlet will clear the firewall no problems on an AE86.6 KB (1,111 words) - 05:28, 27 January 2008
- [[Removing the Air Bypass Valve on a 4agze]]9 KB (1,265 words) - 09:49, 14 September 2012
- [[Removing the Air Bypass Valve on a 4agze]]9 KB (1,341 words) - 09:31, 28 April 2014
- The most common superchargers used on K motor are Toyota SC12 (4AGZE) and SC14 (1GGZE) units. These are readily available from import motors, wr14 KB (2,639 words) - 02:28, 16 September 2012
- ...could use modified aircon brackets and an aircon crank pulley, or modify a 4AGZE crank pulley to suit the K motor.68 KB (12,724 words) - 02:28, 16 September 2012
