I am in need of tension settings for the bigend bearings and the main bearings for a 3K eng. If someone has a book with tension settings in it could you please post a pic of it in here so I can print it out.
Many Thanks to all those that may help.
Rusty
Main bearing bolts: 48 lb/ft
Conrod nuts: 38 lb/ft
Cam sproket bolt: 22 lb/ft
Fly wheel bolts: 48 lb/ft
Clutch bolts: 9 lb/ft
Head bolts: per gasket recommendation.
They're the only ones I'd really worry about. All the rest are just "tight".
Happy engine building! :)
Edited by Redwarf
