olskool1969
  1. Whats model did the insulator plates come out on the carby
  2. I tested the solenoid at work off the car and its ok. I'm just throwing ideas around as the just cutting out is really starting to get frustrating. i've just had the carby apart againg checking for dirt in it. it was all ok. the car is fine in park and neutral. when put in drive it will run for a short time, put your foot down and it cuts out. bugger
  3. It's only a stock 3k-c. its got a new fuel pump, carbs been rebuilt, new fuel lines, tanks been cleaned out. it only happens on the way home from work when its hotter. i do notice under the bonnet does tend to retain alot of heat. it's a very intermittent issue. the solenoid is getting power to it but maybe there is and internal fault with it. where in brisbane could i find one besides wreckers and parts stores
  4. hey, I'm new to this. Can you buy new anti dieseling solenoids? where from? or can it be taken out and blocked off? cheers
