Oyabun
    11
Everything posted by Oyabun
  1. I scrapped the Donor car and didnt think of getting the Vin. I think I found some axles for it. I hope they work! Thanks for the help sir.
  2. So I am doing a manual swap into my Ae82 4ALC, I pulled a transmission from an 87 FX16 GTS. I read somewhere they came with a c52, however mine doesnt appear to be a C52 from the pictures I have seen. It only has one "Ear" but looks almost identical to the c52 otherwise. Basically I need to know which CV axles to buy.. Does anyone have an idea of which transmission I may have, or what axles I need? I pulled numbers off the trans case: 61106943 And off the plate on the trans: 1NXAE89G0, followed by 1Z412164 Does anyone know how to decode this business? Thanks for any help in advance.
  3. Yeah, I am really leaning to a blacktop! The GZE is tempting though. From what I have read the blacktop can't handle any boost though so if I go that route, i would have to build it a bit. Theres a place up here I can get a blacktop with manual trans for 900 US. Not a bad deal compared to some JDM motor sites, and they are local to me so no freight. I am very partial to the dual exhaust! I havent seen anyone else with that kit in my area, and it is way better looking than the factory dual in the R models, imho.
  4. I think a friend of mine had his passenger film when I ran against his bolt on 350z. It was dark and can't see much. I walked him in 5th :wink: Hopefully I get this rolla project going. I would really like something faster now. Still can't decide on a blacktop or a GZE! don't plenty of research and reading so far, but that swap is about a year away anyways. Thanks again all for the info! I will let you guys know how it all goes, and possibly with pics for those doing this in the future.
  5. Thanks for confirming parrot! 7shades, I have a 98 V70 T5 manual trans. Dyno was 239.5 Wheel HP, 330 wheel torque. I believe I have an old pic around...
  6. Excellent, glad to see someone has done it for sure. So to be certain, the entire rear suspension needs to be swapped over? struts, swaybar, hubs, lines, and control arms? Sorry to ask so many specific questions. I need to know what to take off since the car is about 20 miles away from where the actual work will be done as there is no room where the car is stored to house 2 cars. I need to know what I will need to take for certain so I wont have everything apart and realize i needed something else. Thanks for your help, you seem to have done everything I plan on doing!
  7. Will do for sure on the fuel tank. Do you know about the rear struts? On both cars they are 3 stud but as I said, I didnt look close enough as the cars are not side by side. Edit: After a while of searching on google I found this site : http://webspace.webring.com/people/va/ae82power/ae82sus.html Apparently front and rears are interchangeable. Rears may need a bit of modifying.
  8. Thanks for the help guys. I also have a post on the AE82 owners forum, but this one seems a bit more active. My running car is carbed and the FX is injected. I should have mentioned that, and from what I understand the whole tank should be swapped. Am I wrong? The donor car was also used as a offroad racecar of some sort, so the interior is gutted and the dash is not in the best of shape. Since they are both AE82 chassis I am assuming at this point the suspension will swap. I know the fronts have a 4 stud top and mine has a 3, but theres a plastic plug where a 4th would be. The rear struts look different however, the brake lines are not in the same location I know that. I don't have them side by side so I have to go by memory. If the rear control arms are the same then the rear swaybar should bolt in as well, I am hoping. Ill be doing what I can this week, so Ill see how it goes and come back and confirm any fitment issues. I am getting really into this car. I'm a Volvo guy, just finished my wagon up and moving on to this. My Volvo has been parked since I got this corolla and I havent missed it yet :wink: Thanks for the insights guys, this forum is great.
  9. Sorry, I wasnt sure it was called something else out of the states. Its a 2 door hatch with a 1.6 4AGE. AE82 chassis. Picture attached. From what I have read it looks like AUS didnt get the fx16, but hopefully theres an equivalent. It was only released up here for 2 years I think, and there is not much aftermarket or information on them that I have found. This would be a US FX16 GTS
  10. New to the forums and to Toyotas. I recently aquired a 1986 Ae82 5 door for 100 bucks. The beast runs and drives, but its an automatic. A few days ago I got an FX16 parts car complete with a manual trans, pedals and all, Also for 100 bucks. Ill be doing a manual swap shortly. I just have a few more questions as I want to get everything off of this car that I possibly can before junking it. I have read that the front struts can swap directly over? Can anyone verify this? I also would like to know if the rear strut assembly can swap over as well as I would really like the rear swaybar and rear disc setup. Does anyone know exactly what needs to swap over? It maybe easier to just swap the whole rear strut assembly with the hubs and all attatched if possible. My parts car has good shocks and Id like to swap them over as well. I plan on doing a blacktop swap later on so I guess I should save the fuel tank and pump.. Am I missing anything I should save? Any information and insight would be really appreciated. Thanks guys. Edit: Forgot to mention I was told the motor has a bad headgasket. It has already been torn down and missing a few things. I don't think Ill be swapping the 16v in.
