canon
    24
canon's Achievements
  1. Sorry guy for not posting for quite a long time. As for the project well, the was fitted and thanks to A1 for the tip regarding the gear lever mechanism being reversible to move the lever a few cm forward. The engine fired ok BUT the problem is with the thottle body for those not familiar with the vvti the throttle jacks fitted to the throttle body allowing the throttle full activation. In other words in my case the throttle would go half way without oppening the throttle flap triedto find why coudnt.the Rpm is not workin too Any guy who has any idea on the vvti throttle activation whether rpm not working has to to do with it :P
  2. My atempts to start a project thread has failed when ever i proceed to start a project thread every thing goes okay until when i attach a picture and the screen becomes white and freezes :) Is it the forum or my PC
  3. Yes I better start a project thread :) which one :) Hiace or Hilux or Townace or liteace 4 or 5 studs Hilux diesel or petrol :)
  4. A1 I might understand when I see the gearbox which is at the garage, I really need to forward the gearshift to avoid cutting the structural beam which the Ke70 desperately needs especially with more bhp. And another problem is the swaybar (stabiliser) the oil sump is in way of the swaybar :)
  5. A1 thats a excelent looking engine bay. :jamie: Ive been to your site and seen your conversion brakes diff makes things easier for me :D
  6. The gearshift position Some more cutting necessary
  7. The removal of the reliable old engine In goes the the other engine The cross member with the support cut out
  8. By the look of the altezza engine and gearbox with back shift position the gear lever will be infront of the rear seat :jamie: What other shifter will fit this gear to bring the shift forward. :D
  9. Thanks again TRD yes I checked the AFM on the 2004 camry and the part number is identicle to Altezza afm number
  10. I'm from Dubai and yes we drive on proper side of the road :D For those familiar with this swap the brake booster will be on the opposite side of the intake manifold (clearance problem) :jamie: Give Ideas on repaint colours something mature not shouting look at me colours and low profile for the law inforcers as everywhere!
  11. The wiring plus the ecu The speedo while taking it home The wiring plus the ecu The speedo while taking it home The dashboard with no cracks
  12. Thanks to you all . Yes thats what I'm hoping to do with your valuable help and experience. I have RWD 3sge beams manual transmision.It has part of the wiring and the ecu. the car the ke70 . Before i start i want to get the diff.So off to the jdm suppliers I went equiped with my measuring tape because it seems the width of diff is the only deciding factor I have hoping to find something close to width of ke 70 with the bonus of lsd, 4 or 5 studs. I will post pictures of the diff once i locate it.
  13. Thanks Tiger I need your support on this project.I'm trying to collect all the required parts Lsd dif hydraulic clutch Bigger brake booster Fuel line and pump or Efi fuel tank
  14. Just Bought a 1982 ke70 what do you think?
  15. [The engine has been purchased Finding a clean car was difficult But an acceptable condition 1982 ke70 has purchased. now may be its time to start a new project thread
