Bigport 4Age Problems
How do i go about checking this, have followed the book the test the tps and all in spec. The car seems to want to run a lot better with timing say at 30is(unbridged) doesnt ping or anything just seems happier up there? But obviously somethings wrong. (yes cam timing and everything else is 100% correct)
No error codes at all, just flashes showing no code... Which metal lines are yoy talking about mate? Ive blown thru all my fuel lines and they are clean. Unpluging tps seems to make it worse? Havent tried map sensor, shal do
Sorry for the late reply, have been busy at work. Took injecters out and cleaned. cleaned plugs and no more black plug on cylinder one so that problem is fixed. altho seems to have not helped it running like crap still. I'm seriously at a loss to what it is... also set idle again and tried another TPS but hasnt changed a thing still the exact problem i was having before, misses, idles crap, no power etc.. went thru the book and did all the tests to check coil/ignitor etc etc etc all in spec any idea where to go now?
brandnew plugs ran for 5mins SPARKPLUG CYLINDER ONE SPARKPLUG CYLINDER 2,3 &4 also a video of how its idling, it will idle like this and eventually stall out on its own.... http://vid735.photobucket.com/albums/ww360/smackdownz/20150814_171541_zpsv8k6rr3x.mp4
Hey guys,got a new project and having a few problems getting my bigport 4age to run properly in my ae86. MAP sensor'd cars undrivable at the moment, if i give the throttle a real quick hit and bring it up to say 2500rpm it misses and backfires and carrys on, if i move the throttle slowly to 2500 not a problem at all idles like crap (see vid) What ive tried; Have statically timed (everything lines up, cam timing etc) timing is at 10BTDC with diagnose bridged (timing is pretty erratic, 10degrees for 2-3 seconds then jumps to 15 then back to 10 etc etc..) compression check 140-145 on all 4 cylinders checked vac hoses TPS adjusted and in range Cleaned iscv/throttle body new gaskets everywhere new dizzy cap new plugs new leads all sparkplugs are sparking Any ideas?
smackdownz
