StuC
New Member
StuC last won the day on January 17 2017
StuC had the most liked content!
  • Real Name
    Stu
StuC's Achievements
  1. what he said!
  2. Hahah, no worries dude. Good luck with the sale. She looks fantastic and I'm sure will go quickly
  3. If only!! Swap for the starlet Adam? Oh, your Picasa link doesnt work properly either
  4. bump.....need to get rid of this.
  5. The rear wheel caps are in the boot along with the silo wheel
  6. Bump - i thought this had shat an oil pump but it turns out my brother just overfilled the thing. I did an oil change tonight, topped up fluids and took it around the block. Still will need the timing belt adjusted but with a couple of hours it will be back to being a nice car with a long service history. I really need this gone as the missus is at me to clear some room at home Come at me!!!
  7. 1989 Nissan Skyline Silhouette, Series 3 RB30, 3.0L inline 6 cylinder 4spd electric auto 247,xxxkms White over silver two-tone with Silhouette highlights Grey/red silhouette sports interior Standard with the 3.9 Borg Warner LSD Located in Melbourne, Vic A little history to the beast: This car was bought new by my mate’s grandad who passed it onto him for his 18th. He Drove it around for a few years and then parked it up as he was given a company car. It sat around for about a year and he then sold it to my sister (late 2009) who drove it for about 3 years. She went overseas Christmas last year so passed it onto my brother. I’ve maintained and serviced it since my mate took hold of it back in 2003 and know it like the back of my hand. Being a Silhouette it comes standard with the 3.9 Borg Warner LSD, sports interior and body options. To get it on the road for my sister I did the following: • Monroe inserts fitted to the front end • Front lower balls joints replaced • New pads and discs all round • New handbrake cables (factory new from Nissan) • Rebuilt rear brake callipers • Replaced rear trailing arm bushes (2 per side) • Replaced leaky power steering hoses • New front windscreen • 4* Maxxis tyres Maintenance: • Recondition alternator (bearings, slip rings, bushes, regulator) • New battery • Idle valve replaced • Steering rack bushes and column bush replaced with Nolathane item • Plugs, leads, coolant, oil and filters when required • Auto transmission flush and adjust + replace 1st-2nd shift solenoid In the last 12 months it has had the following: • New PBR brake master cylinder • Rebuild of rear callipers • Replaced front brake lines including making new hard lines • Full brake fluid flush/bleed • Timing belt and tensioner • Water pump • Oil + filter • Replaced radiator with a good condition second hand item and coolant flush • Had new key cut and door lock rebuilt A couple of months ago the water pump started leaking so I replaced that and did the timing belt at the same time. Shortly after the radiator split so I replaced that and the coolant (as you do). Unfortunately last week it appears the timing belt has jumped a tooth. My brothers decided to not fix it this time around and buy something new. As listed above, it has had a decent maintenance history and has been well cared for and definitely not thrashed, all of the owners drive like grandmas! With a few hours work and a little know-how this can be up and running again smoothly. The motor obviously needs the timing reset and the auto is thumping from 1st to 2nd again (very common on this transmission) but is a simple fix. The AC needs new seals and a re-gas too. There are a few scrapes on the body but no major dings or bumps. I will throw in a spare alternator, the old brake callipers, a spare idle valve and any other parts I have lying around for it. Or if you feel adventurous do what I was originally going to do and chuck an RB25 into it and make it a bit of a sleeper. Unfortunately I already have a track car and a bike in pieces so can’t swing it past SWMBO. Selling in as is condition, with no RWC, no Reg Chasing $1500 neg If you want pics (the uploader isnt working for me) or more info please contact me on the following: Stuart Chambers Email: [email protected] Phone: 03 5428 0475 0415 298 248 PS: Please note, i know this is my first post but i've been lurking here for years, just never signed up.
