rcosa123
Everything posted by rcosa123
  1. Hi to all, I am new here in the rolla club forum. i just saw on the other thread about the 4k-c engine with turbo. I am planning to put a turbo on my 2e carb engine, hope you can help me with my building process. Here is my plan. Using a Blow through setup and CT9 Turbo(Stock turbo of 4efte) i am planning to boost only for about 6-10psi with stock internals Here is my Question -Can i use my stock carb for the blow through setup? (i will just sealed the carb in a Tight Air Box?) because i don't know how to jet my Carb, BTW, I'm using Stock AISAN Carb from corolla. -I'm planning to use intercooler, even though i will only run for 6-10psi. do you think its ok? because i know that intercooler is not really necessary for low boost purposes. -What type of Pressure regulator can i use to have enough fuel supply on the carb? also the electronic fuel pump. Hope you can guide me through this project. if you have any tutorials or link that can guide me in jetting the AISAN Carb for turbo purposes, kindly post it here, Thanks. :)
