I'll try to be brief:
Q#1) I'm a disabled senior with a balance problem (I can't stand long and I fall a lot). Anyway, we have a 1995 Corolla (base model, 1.6L, automatic transmission, 172,000 miles). It was my birthday, It was 105+ outside, and I had a coupon for a full synthetic oil change for $19.95, and the tire and lube place had just changed my wife's car oil without any problems. So I had them change the oil, and because it was sooo hot outside, I didn't check the oil level on the engine oil dipstick before leaving. The car drove home great - no issues (14 miles).
Got home & parked the car, where it sat for 2 days. Needed the car and it wouldn't start (crank only and backfire coming out from the air filter box??). Checked the oil level and found that it was way over-filled! Used a fluid extractor and took out about 5 liters/about 5-1/2 quarts from an engine that only takes 3.2. quarts. We put in the correct amount of oil and got the car to start (by holding the gas pedal down while cranking - after a few more back-fires) Ran fine again for a few days. car sat again for a few days and when we went to drive it - again, crank/no start.
The backfire is telling me it's a timing issue (curious how this only started after the over oil change), not related to the oil change mistake. Pulled the plugs and they were fouled. Put in new ones and again got the car to start - again after some backfires through the air filter box & by holding the gas pedal down while cranking. Never detected any foam on the oil dipstick or oil filler cap, nor any smoke from the exhaust. All I know is that the car has always started and run great until the oil change. Am I missing something? The car runs great, once we get it started & I'm thinking the starting issue is a timing issue (the backfires indicate this to me).
Q#2) What are all the different size light bulbs on the instrument cluster? I know that the main 3 bulbs are #194 bulbs, but I don't know about the rest of the bulbs, and my old eyes can't see any identifying bulb number. Is there any way to make all the bulbs on the instrument cluster illuminate at one time? This would be helpful in knowing which ones are out before changing them.
Any and all help is appreciated!
