KE70 Spec: D
Everything posted by KE70 Spec: D
  1. yea cool.. hey are the falcon springs the same on the front as well as the back???
  2. hmmm. so i need corona LCA's, and do i need radial arms and steerin arms as well??? I'm pretty keen on about 2.5-3* camber on the front, so i mite try and find some some gh sig ones... dunno, i guess its a bit of try and see what i like when it is driving... cheers for the help guys, any other good ideas???
  3. oh and should i maybe use the sigma brakes as well?? they are a fair bit bigger, and they are comin with the susp. setup...
  4. sounds like the timin was done 180 degrees out, and they changed everything else to match instead...
  5. well i am gettin them cheap anyway, i mite put them on and if i don't like them, see if a wrecker will swap for GH arms.. btw i am not running camber tops, just the LCA's and probably falcon springs... what falcons do they have to come out of??? is it just E series (EA, EB etc) or somethin else??
  6. well i mite get em any way and try and get them to fit... 3.5 deg. neg camber.... sick!!! nothin like chewin thru tyres!!! its a semi drift car, or will be soon anyway... so that camber will be nice...
  7. hey guys wonderin if the sigma control arm conversion on a KE70 has to be out of a GH sigma?? i can get a full front suspension out of a GJ sig cheap, wonderin if it is the same and will fit?? cheers Matt
  8. would it be possible to use sigma front brakes?? as well as the LCA's and stuff for camber??? they are a fair bit bigger, and u could probably get them fairly easily from a wrecker...
