Hello. I am from Bulgaria. Kia Cee'd 1.4 petrol 101 hp, 2012-2018. Warranty is (almost) over, so I changed the oil myself for the 1-st time, but the oil filter that I ordered from the online store, although I indicated exactly my car model, turned out to be larger in outer diameter and it was not possible to screw it in, since the location is such that it does not allow this. Since I drained the oil, I found an open shop on Saturday and managed to buy a filter (champion), which is the same size as the original one, but apparently has a third valve inside. Even the seller opened some thick notebooks and said that this filter has a third valve, while the others have only two valves. By two valves I'm assuming that means a bypass valve and a valve that keeps the oil from draining. The filter I got is CHAMPION COF100116S. In the web page it says: "w/ Anti-Drain valve, w/ Anti-Syphon valve, with By-Pass valve".
I have this concern:
Could using a filter with an Anti-Syphon valve have a negative impact, i.e. make it difficult for the oil to move at high revs or something like that? Because, on the web page of this filter they say it supports KIA SPORTAGE and KIA RETONA, but nothing about Cee'd.
I am about to make 2 quite long road trips in a week with lots of highway driving at high speeds, so I am worried.
P.S.: If I buy an original filter, will it be OK to try draining the oil into a clean container, change the filter and refill with the same oil, or is that a bad idea?
NOTE: My filter sits quite low and also is upright, but still, if I leave the car for 5 - 7 days, I experience rough start.
