FONX
  1. Hi all, I am putting an sc12 on my 5k, running it through a 4k efi setup. I have already done a search on here, and elsewhere and have found a lot of interesting material but am always after more. What I am looking for are pictures of this kind of setup or similar, specifically how the supercharger is mounted (in as much detail as possible), as we have only an idea as to how to go about doing it. Are all sc12s shaped the same way, with the inlet on the dipstick side and the outlet facing away from the pulley? How did everyone get around this? Also interested in what ecu I should use and also where I should get it from, and maybe a heads-up on any other trouble I am likely to run into. Thanks P.S, I just thought of anther two points, what ehaust size is ideal for this setup, would 2 inch do? and I read about throttle body before and after supercharger making a difference in noise and performance, which is best? and is the noise likely to cause problems for a warrent/cert? And also a larger throttle body is supposed to be better, which one could I use? Thanks again
