beauistheman
    3
Everything posted by beauistheman
  1. Hey I'm just gonna change my AE82 4AGE passenger side drive shaft. Is there anything i need to know that can make this job easier to get the shaft out of the disc hub? I know theres 6 nuts on the gearbox side and then the wheel nut with split pin. Anything that you can tell me that will make this job eaiser will be much appreciated. THANKS!
  2. Thanks heaps for that info mate, i was about to jump the diagnostic set but then i just checked again. Checked the pump and spark again, pump works beautifully, but no spark. Gave the dizzy a bump while cracking it and it started. I guess that means its those magnet/coil things in the distributor eh? So ill have to do the timing again....Any tips? Is the clearence for those magnets and the center piece 10thou?
  3. Hey, she just stopped starting. Turns over fine. Checked all leads/plugs/distributor/coil. Nothing. Now i believe its the fuel pump. Is it fair to just remove the piping from the filter to the manifold, turn it over and see if any fuel is pumped through? Also, could it just be a relay? If so where is it and how can i check it? If the pump is gone, do i need to drop the tank or can i access it from outside somehow, because i can't see it. Thanks for the time.
