Everything posted by kairazy
4k-c Piston 1 Not Firing
I havnt fitted the gasket yet. I m just assuming thats the problem at the moment
Umm yeah that right. I just did it to test it Whats wrong with that? Na i don't have extractors. I already did up all the manifold nuts, but it dodnt fix anything.
I think ive worked it out Its the manifold gasket, when i pur petrol over the inlet the piston fires up, briefly.
Thats what i thought
If it is the valve, would it still have commpression though?
Its sparking because we pulled the spark plug outattached to the leads and it was sparking. I know the cylinder is not running as we took out the plugs one by one and when no. was pulled out it didnt make a difference. Whereas when the others were taken out, it ran much rougher. Ill will tyake the rocker cover off to check the exhaust valves thanks
Yeah, sorry the spark plug is firing so there is a spark, But the cylinder is not running for some reason
My Ke is running on 3 cylinders at the moment. I did a service on it last night and changed the spark plugs, leads, point and did the timimg. But cylinder no.1 is still not firing. I did a compression test and its at 185 in the cylinder so it has good compression. Does anyone know what it could be, I'm stumped
