corey70
    2
Everything posted by corey70
  1. iv started doin my sr conversion into ke70, heres the link to my build thread so far, not very far into it yet tho http://www.ae86drivingclub.com.au/forums/s...read.php?t=2291 edit: BTW I'm doing s13 suspension and s13 sus works fine (if you don't mind the extra track and camber) if you use all nissan parts eg-x member, coilovers, brakes, hubs, control arms... search for simonke70's ke70 on ae86 dc he's done s13 suspension and is apparently 1 of the best steerers out there. most the well known names running sr in there ke's have s13 front apparently... simons sr20 ke70 build thread, well worth a look http://www.ae86drivingclub.com.au/forums/s...hread.php?t=721
  2. corey70
    Sr Ke70
    hey mate, is that a silvia cross member redrilled to fit or did you cut and re-weld mounts onto the ke crossmember? Was there much tunnel work needed to be done? also with the gear stick, i thought it had to be re-cut abit further back? I'm about to tackle a sr conversion in my ke70 so info would be great. cheers
