oversized 86
    9
oversized 86's Achievements
  1. all wired up and working overrated now...cheers
  2. and viola...thanks to berserker
  3. i chucked the blue shell out before i even thought about that...
  4. still need help with this... even if someone with a T18 can just expose the wiring going to the coil and then take some photos that would do the job... cheers
  5. Hi, I'm currently putting in a 2tg with twin carbs into my T18 and have come accross a problem... I'm in need of a wiring diagram for a T18/TE72... in particular the engine bay diagram... i need to wire up my coil, as the standard coil wire's were cut out when i converted to 4age...stupid wiring guy did it without telling me... this is one of the last things i need to get the car running any help is appreciated Cheers
  6. how old we talkin? mine is probably about 6 months old
  7. ah spewing...can't really afford the $400 odd to get a re-map at the moment... oh well...back on the shelf it goes
  8. wouldnt the booost pressure sensor or whatever be linked to the map sensor input? there is only the map sensor vacuum input on the ecu
  9. Hi, i have a brand new Microtech LT10s sitting here, when i ordered it i was going to be building a turbo 4age, from a MAP sensor, Dizzy, Bigport now i have changed paths...i am going to be building up the 4age with quad throttles etc can i use the base map that is currently on the ECU for the NA setup? or will i have to send it back to microtech and shell out some $400 odd to get them to put a new base map on it? any help will be appreciated cheers
