zoinks
    2
Everything posted by zoinks
  1. well i dunno, but how much stronger can the ke55 diff centre be if it uses the same diameter axles as the 20?? they have both been designed to handle almost identical engine specs...
  2. I've done KE55 gear into a KE20. Front and Back. For the back u need to do what the guys have said above. Shorten the KE55 axles a few mm after making sure the diffs are the same type. U need to use the complete KE55 brakes. It will give you the 114.3 stud pattern and bigger brakes! Offset will remain unchanged because u will cut the axles to the same length as the ones u pull out.
