I was just wondering what TRD ke70 meant by this. Are the 7K-E ports only bigger against the manifold? Or will the performance detoriate if the exhaust ports in the 3K big port are opened up? I'm not a native English speaker, and I certainly not an expert on K engines, so my question could certainly be better formulated.
I was thinking of a big bore 7K-E engine when I wrote the question. In that context there are some reasons for going for a 3K head: You can use flat top pistons, which are easier to find than dished pistons. Flat top or domed pistons can allow for shorter compression height and lower weight of the piston, which will allow for a slightly longer con rod and a more rev happy engine. You will get adjustable valve train, which is good for installing a reground cam....I believe the valves are already bigger in the big port, which is crucial in order to get the 7K revving better as well.
I have already confessed that I'm not an expert, so I won't be upset if someone sets me straight in these matters...
