Hi Guys,
The paint on my KE30 is in pretty good condition, & has cut & polished up well, except for the bonnet & boot lid, which are starting to "crazy crack" in areas. 40 odd years of sun baked paint, & very, very hard.
Yesterday afternoon, I decided to try a test patch on the bonnet to see how hard it would be to strip it back to bare metal. Some "Diggers" paint stripper I had on the shelf from Bunnings, took ages to remove one layer, and only bubbled on edges of flutes in the bonnet, where the paint was thinner. I then used a 80 grit orbital sanding disk to break the surface of the paint to let the stripper do its thing, and this certainly sped things up a bit. However there were spots where I had to use the sanding disk right to the bare metal, which obviously creates small scratches, that any good self etching/filler/primer will fix.
I decided, that gently breaking the paint surface to let the stripper work effectively is the way to go, but I do want to find the most quick & aggressive stripper available commercially, so that I can get all the paint off quickly, and devote most the time I have available, to preparing the paint free surface.
What brands of auto paint strippers have you used & found very effective. I've noticed that paint stripper prices can vary widely, with some twice the price of another, but I've found in the past that a higher price for a product, does not necessarily mean it is better at doing a particular job.
Any thoughts or suggestions welcomed.
Cheers Banjo.
