Search the Community
Showing results for tags 'volvo B230FK ke70 turbo'.
HI I'm new here but have been lurking around for some time now. This is my 1980 corolla wich I have owned for 3 years now but first started to work on about a month ago. still a working project but will hopefully finish the mechanical stuff in 2-3 weeks I'm putting in a Volvo B230FK engine and m90 transmission. With 700cc injectors and 16t volvo turbo and about 18-20psi it will be around 250+ hp All controlled with MS3 I used s13 running gear in the front but with custom made lower control arms. s13 coilovers front and rear I put a 1980 hilux rear axle and vw rear brake calipers and SSangyong musso brake discs. some pics of the process last year I had already fitted a ca18det engine and transmission, but when I took the engine apart I realized that the engine was blown. had to cut a little bit into the firewall not much room in there test fitting the engine finishing up the x member Lca´s in making AE86 tophats and a brake master from a MMC Pajero and ofcourse hydrolic handbrake refurbished s13 calipers MMC evo 8 seats radiator from a Ford transit diesel 16t turbo original from a volvo 850 T5 test fitting after making the lower brackets and with tires gas tank from a wrangler made to fit :) everything ready, just waiting for the coilovers to arrive so I can finish the rear axle in the meanwhile MS3 was connected up and it fired up and idled nicely in first try Coilovers arrived and installed in the front
