December 31, 200619 yr comment_157467 Hey guys, my name is sam, just wondered if anyone could help me out. I own a ke70 running a stock 4k, and recently had issues with water leaking into the combustion chambers due to corroded water jackets. So i ripped off the 4k head and bolted on a 3k-h head (i think - number 33)with a new head gasket, and extractors at the same time. Now when i try and start it, it sounds like theres no compression building up and the motors just freewheeling...i can't figure out where it would be loosing compression, and i know the timing and timing chain is fine...any ideas? Edited December 31, 200619 yr by raceflorolla Report
December 31, 200619 yr comment_157468 Did you readjust your tappets? Did you do anything with the valves? Did the head come of an engine that you know was running? Cheers, Rob Report
December 31, 200619 yr Author comment_157470 I havent readjusted the tappets...but ill go do it. I didnt touch the valves when it was off, and the guy i got it off rekoned it was running but i never saw it! Sam Report
December 31, 200619 yr comment_157474 I havent readjusted the tappets...but ill go do it.I didnt touch the valves when it was off, and the guy i got it off rekoned it was running but i never saw it! Sam i sold a 3k head to a guy and he did exactly what you did. the head face is lower so when you bolt it up and put the rocker gear on, the valves are held open causing no :y: compression. Cheers, Rob Report
December 31, 200619 yr Author comment_157475 Your a ledgend mate...you learn something new everyday :y: ...it makes sense, just didnt think of it! Report
