August 2, 200719 yr comment_189836 Hey All, We'll my radiator is shagged in my KE Panel Van and I have to fix it up as a last little herdle to get it on the road. I've noticed there are some little differences between the panel van radiators and the sedans (not sure about the wagons). Anyway I reckon its gonna cost a heap to get my 26y.o. radiator redone so my question is; Whether you can replace it with a standard KE sedan radiator instead, and if anyone has done this? The Panel van radiator seems to be smaller than the sedan ones and has a wide mounting plate welded on the sides to make it fit the radiator support mounting points, this makes me think that a standard sedan one will fit the rad support mount points perfect? If someone could measure up their radiator or mounting points, it would be greatly appreciated Extra Info - The radiator is for a manual, and It is the one that you bolt the plastic shroud up to not the one with the little metal shroud welded on... As I mentioned this is the last thing I need to do to get the roadworthy, help bring another Rolla Pie-Van back on the road!! Cheers :n: Chris Edited August 6, 200719 yr by goldke70 Report
August 2, 200719 yr comment_189925 Hey All, We'll my radiator is shagged in my KE Panel Van and I have to fix it up as a last little herdle to get it on the road. I've noticed there are some little differences between the panel van radiators and the sedans (not sure about the wagons). Anyway I reckon its gonna cost a heap to get my 26y.o. radiator redone so my question is; Whether you can replace it with a standard KE sedan radiator instead, and if anyone has done this? The Panel van radiator seems to be smaller than the sedan ones and has a wide mounting plate welded on the sides to make it fit the radiator support mounting points, this makes me think that a standard sedan one will fit the rad support mount points perfect? If someone could measure up their radiator or mounting points, it would be greatly appreciated Extra Info - The radiator is for a manual, and It is the one that you bolt the plastic shroud up to not the one with the little metal shroud welded on... As I mentioned this is the last thing I need to do to get the roadworthy, help bring another Rolla Pie-Van back on the road!! Cheers :n: Chris I got a Brand New radiator for my AE71 pano from Red Devil at Virginia for $450 installed, so I highly recommend them :D Report
