November 28, 200718 yr comment_211878 ok I have a 4k with twin asian carbs .The car starts and idles fine but after reving it up it goes back to idling then dies.It is also only running on the front two clyinder when idling any ideas?cheers Report
November 28, 200718 yr comment_211885 ok I have a 4k with twin asian carbs .The car starts and idles fine but after reving it up it goes back to idling then dies.It is also only running on the front two clyinder when idling any ideas?cheers Just check the following it may help. Vacuum leaks, test , clamp brake booster and PCV hoses to test is one of the needle and seats stuck? Have you connected both fuel cut offs up? is one of the secondarys stuck open. Edited November 28, 200718 yr by KE30_KE35_KE55 Report
