February 6, 200818 yr comment_225939 Hi everybody. This is my first post here so I hope I'm not doing it wrong. :y: I just picked up a 1992 AE 95 wagon. The suspension in the top of the struts has play and makes noticible noise when hitting any sort of a bump. Ive deducted that it is most likely the strut support at the top that needs to be replaced. BTW can I get aftermarket ones if so where? Is this a weak link in the suspension on these? :bash: Now the real question since I'm replacing this part of the suspension which means pulling it all apart I want to lift the girl up a bit (up to 2") but wouldnt you know I can not find lifted springs anywhere. ;) So does anyone know what I can do short of getting customs built? Thanks everybody for your help. Report
February 7, 200818 yr comment_226100 King springs will make you customs ones but be prepeared to pay a high price. we struggled to find super lows for ours.... after much arguing and research we have ae86 super low fronts and commonhwhore super low rears. Report
February 7, 200818 yr Author comment_226134 Thank you for the responses. surely there is another vehicle out there that uses the same diam. coils as the AE95 that might be a suitable canidate. Could anyone tell me what the factory spring Diam is, the extension/compression measurements along with the spring weight? Even just the diam would help alot. I can tell my project is going to be frusterating...oh well shell be worth it. :) thanks Report
