Ke10 Strut/brake Options?
Hey guys, I was just wondering if ke20 struts are a bolt in fit for ke10s? Or alternatively can the ke20 discs, hubs and calipers bolt up to ke10 front struts using all the ke20 bits and pieces ie brackets and lines?
Any help would be greatly appreciated.
Reckon you are lucky the regulars haven't growled at you yet about reading the FAQ! Having had a look myself, if you go to the Knowledge Base/FAQ link at the top of the page, you will find all you need to know about fitting discs to your KE10 there.
haha yeh. They must be in bed early or something.
The FAQ has a good guide to putting ke20 discs in, and a brief item on how to use replacement ke20 inserts as ke10 ones are difficult to find new.
There is further info in a deeply stashed thread CLICK on how to convert to ke20 strut tops and springs and subsequently lower the car properly, which is difficult to do with the original suspension.
In short, no, they are not a bolt in swap, but it can be done with some mix and match.
