hey guys.
i just wanted to put the question out there as to what you specifically need to mod in the corona struts..
heres my idea, but i this is a collaboration of other peoples + a few of my own.
corolla top hats, cut ford EB springs, corolla spring seat, corona strut leg, corona steering arm, corona RCA, corona brakes (caliper and disc) for the front.
NOTE: brakes is for the time being, i plan to go up to the hilux/peugot upgrade when i can.
KYB VN wagon shocks and cut ke70 springs in the rear.
note that my car isnt aimmed specifically at drift but grip, so i don't want the stiffest back end.
i just want to know from others:
1. if this is the correct way to do it or if the corona strut COMPLETE bolts in or what.
2. what shocks do i run on the front end if i want to lower my car about 2 inches.
3. do the ford front springs from the EA-EB falcon go into the front of a ke70.
i can't really afford to have my car off of the road for long, so i need to know this stuff so my car isnt gonna just sit there while i need to be at work, earning the money for later upgrades :S
cheers.
1. use bare corona strut and xt130 lower control arm (this will give neutral camber instead of positive)
2. st185 celica standard length insert
3. not sure, there are two different falcon spring sizes and 1 of them doesnt fit.
i had corona struts in mine with stock ke70 top hat and ke70 king springs in the front.
