Everything posted by japlish
3Rzfe Into Ke70 -
R150 gearbox fits in a ke70/ae86 tunnel too
3Rzfe Into Ke70 -
no it wont be, 940kg (ke70) x 2.7 = max turbo cap = 2538cc
3Rzfe Into Ke70 -
hence why I'm building a turbo 2rzfe :) = 2.4L
3Rzfe Into Ke70 -
I'm currently putting a 2rz into an ae86, I bought the front sump from the USA, part number 12101-75041. You also need the oil pickup and dipstick to suit, I bought them as well but the numbers are around....somewhere. you still have to cut a section out of the underside of the sump but no biggy really. and space the crossmember down 20mm
4Afe To Rwd Setup Ke70
Unless you buy the ignition setup (possibly head too) from a AT211 corona from nz......dli ignition no dissy :)
Sr20 Into Rt142 Corona.
there's a guy on ae86DC that has this setup, goes alright too.
Ra65 St Coupe
3rz swap would be ideal :) Give me a few weeks and i can get kings into work.......
Peanut Bait
what struts do you have? I'd say the teflon coating on the s/c blades is cactus........
Brent's Ke30('s)
you got that 2 door from rocky?.......
The Rwd 2Az-Fe Thread.
lookin good man :)
Ke30 3Tc Wiring
74 Model, i did find a ke25 wiring diagram in this forum but the writing is too small to see the colours...........
Ke30 3Tc Wiring
Main plug? Plug at the bottom
Rians Ke70
i redrilled one hole in the strut tower to flip my ae86 T3 plates left to right.
Ke30 3Tc Wiring
ok so i have been doing a 3tc into ke30 2 door swap, problem is the ke30 came with no engine. As far as starter and alt wiring goes that's sorted because the t18 and ke30 both had external alt reg's and the wiring was the same BUT, I have a large plug with a white wire and a red wire left and another plug nearby running off that one with a single white wire. I'm guessing they go straight to the battery with a fuseable link?? Problem is all the wiring diagrams for ke30/50 have different colour wires to my car and they don't match up! they never show enough detail! Could someone take a pic of their stock 3k/4k setup near the battery/starter please?? :D
7K Stroke
doesnt 7k's and 7afe use the same rod's? if so get some SPOOL rods.
- 2Jz-Ge Into Ke70 Conversion
Ra65 St Coupe
i have two manual steer racks :)
Ben's Low-Roof Panelvan
i would have swapped you my AE71 wagon for this :D
Sigma Lca's Ball Joints????
meh, enough not to be a problem.
they do fit....just. i have used them before and had no problems, the knuckle just sits higher on the balljoint taper.
there is no other alternative buddy..........
Ke70 Parts Into A Ke36
Brakes aren't that different so not worth the effort, box will fit but have to cut out the shifter hole further back
My Ke36 Panelvans Addiction With Boost
BANG!!
3T Into Ke70
Nope it's just easier to make new block mounts, if you can't weld them make them from wood if you have to and then get them copied...
