November 6, 201313 yr comment_671121 Hey guys just after abit of help/advice, I have an rt142 corona 2.4L, Thinken about doing an sr swap cause the 22re is overheating, and ive tryed everything to fix it, (think its head gasket I'm just in denyal) So i have been told if i get s13 engine mounts and perhaps an s13 xmember, can anyone tell me if thats true? As for a 20 det gearbox anyone know if I'm gonna have to cut and weld the tunnel for length? I got no clue n have look but can't find much. I know ill need a tailshaft made up, and I'm gonna go with shortened 31 diff, n ive already done brakes and suspension in the front, I'm budgeting about 3k to get it in n running, just need a few answers before i set off haha :) Thanks in advance Report
November 6, 201313 yr comment_671135 I worry that you haven't budgeted enough. Though $3000 would build an awesome n/a 22R. Report
November 6, 201313 yr Author comment_671136 Its only an na SR build and ill be doing everything but wireing myself and perhaps the gearbox mods, i want solid skid power till i get a turbo, i can always jack the budget up too its just what I'm looken to do it for. My main concern is where the gbox will sit in the cabin haha Report
November 6, 201313 yr comment_671150 Yes I see your motivation now. Nonetheless, I reckon 3 grand could make your 2.4 litre 22R own a stock n/a 2.0 litre SR20. No mod plate required. Yanks do crate motors wiv them and shit. Someone put one in a KE55. http://r.ebay.com/humH2J Edited November 7, 201313 yr by Mechanical Sympathy Report
November 6, 201313 yr comment_671173 If you are hell bent on the sr20 i think you are better off fabricating some new mounts to mount the sr20 to the standard cross member. Then it leaves all the suspension and steering the same. I reckon it can be done for 3k, hardest part is going to be the formentioned mounts and then a custom tailshaft is going to cost you a few hundred dollars. You already have an EFI fuel syetm, so you just have to wire the engine in. does the 22RE have a hydraulic clutch or a cable? If its hydraulic already then you're set. Report
November 6, 201313 yr comment_671174 there's a guy on ae86DC that has this setup, goes alright too. Report
November 7, 201313 yr comment_671244 Ive looked into modified 22res. No way could you even approach the same hp as an sr20 NA. The head is a huge restriction, as is the inlet manifold. Without a massive amount of headwork you can't make more than 120hp on a stock motor even with cams. Edited November 7, 201313 yr by LittleRedSpirit Report
