July 6, 200818 yr comment_258674 hey i brought a ke70 not long ago, was going alright, but left it for a few weeks now its like no idle, ive replaced spark leads, sparks plugs, fuel filter, air filter, basically a service, but ive tryed to get the idle right, but as soon an u put in drive ( auto ) the idle dies down an almost stalls, even if u set the idle high in park soon as goes into drive it dies down an stalls an go for a drive around the block, an then come back an wont even idle in drive will just stall :D but in park will idle fine i have no idea what the problem would be can anyone help plz ? Edited July 6, 200818 yr by ke70black Report
July 8, 200818 yr comment_259231 hey i brought a ke70 not long ago, was going alright, but left it for a few weeks now its like no idle, ive replaced spark leads, sparks plugs, fuel filter, air filter, basically a service, but ive tryed to get the idle right, but as soon an u put in drive ( auto ) the idle dies down an almost stalls, even if u set the idle high in park soon as goes into drive it dies down an stalls an go for a drive around the block, an then come back an wont even idle in drive will just stall :D but in park will idle fine i have no idea what the problem would be can anyone help plz ? would your idle mixture affect it Report
July 17, 200818 yr comment_261733 had what sounds like the same problem in my 25, wouldnt start or idle unless you push started i and kept it reving above 1500-2000 just grabbed another carb, cleaned it and stuck it on, worked perfectly. i think it was a stuffed idle system or jet?? CHEERS Ryan Report
