Ke55 Front Springs?
Hey just wondering if someone could give me some help on what i have to do to swap the front springs on the ke55?
cheers rundell
Remove strut: Calipers off. Remove brake line from strut. Two bolts at bottom, three at top.
Install spring compressors. Not essential, but a big help.
Remove big arse nut from top of strut shaft. I use a rattle gun, and can be tricky if you don't have one.
Remove spring.
Install is basically the reverse of the above.
sounds pretty easy was just checking before i started it and stuffed it up haha. yeh got the spring clamp things so should be easy and a air ratchet so piece of cake hopefully :sob:
