luke.t. Posted October 13, 2008 Report Posted October 13, 2008 hey all... got a problem with my rear suspension setup on my ke. for starters it has sierra short stroks and cut kings (free height 220mm). the thing is my mate has the exact same setup and his is a bit bumpy but not over the top. where as my ke is like a friggin jumpin castle on wheels. i have put in some cut stock springs in (free height 300mm) and still the same :wink: if any one has any ideas/suggestions on what to try it would help heaps cheers luke Quote
bLinded_ Posted October 13, 2008 Report Posted October 13, 2008 hey all...got a problem with my rear suspension setup on my ke. for starters it has sierra short stroks and cut kings (free height 220mm). the thing is my mate has the exact same setup and his is a bit bumpy but not over the top. where as my ke is like a friggin jumpin castle on wheels. i have put in some cut stock springs in (free height 300mm) and still the same :wink: if any one has any ideas/suggestions on what to try it would help heaps cheers luke I was under the impression that 220mm freeheight springs would be too tall for Sierra shocks. I thought most of the boys run about a 170-180mm springs with them. This may or may not be a problem. 220-230 mm would be much better suited to Commodore wagon shocks (343113 KYB) Also, If the car is running Sierras, I'm assuming it is fairly low, in which case, if you haven't already, the bumpstops will most likely need a ring or two cut off from them. the car may be hitting the stops and causing it to bounce. Quote
5elfori1 Posted October 13, 2008 Report Posted October 13, 2008 http://www.ae86drivingclub.com.au/board/in...spension+thread have you read this bro.... read:droop page three. the amount of rebound the car gets b4 the wheels leave the ground.. ie yours none. ie ideal 2inch.? its a top thread. Quote
luke.t. Posted October 13, 2008 Author Report Posted October 13, 2008 Cheers blinded..... may look into some new shocks maybe... ill play with it on the week end, chop of sum bump lol and see how it goes. may also chuck in my mates rear shocks (they are longer i think) to see if the sierra's are the problem cheers for your input. luke Quote
luke.t. Posted October 13, 2008 Author Report Posted October 13, 2008 http://www.ae86drivingclub.com.au/board/in...spension+thread have you read this bro.... read:droop page three. the amount of rebound the car gets b4 the wheels leave the ground.. ie yours none. ie ideal 2inch.? its a top thread. lol yeah i think that is my main problem. really considering new shocks...... longer ones. that thread tells you a heap aye. i suggest it to anyone one who wants to understand suspension better Quote
