October 24, 200817 yr comment_284120 ok i have a new 4k but there are wiring problems a. no where to plug into near oil filter, another plug on that same lead unknown where to plug into b. wiring on electronic dizzy, as opposed to stock dizzy, it has a plug on it that has 2 spots for wires, where do they go and which goes where? c. on altenator its an aftermarket one with 3 spots for wires and a screw on thing, where do they go as old one only had 1 spot for a plug and one for a screw on thing d. mechanic says that with elec dizzy i need another thing as well as coil??? i just got a coil off an elec dizzy what else do i need now wtf?? help help help asap need it wired and running!! thanks in advance Travis Report
October 24, 200817 yr Author comment_284156 just another thing, will i need an extrnal ignitor for the dizzy, the model number is : D52903 thanks, was hoping to get it wired today so help asap please!!! Travis Report
October 24, 200817 yr comment_284198 the wire near the oil filter should be for the oil press light sender, as for the dizzy, the denso electronic dizzy have a built in ignitor but 9 out of ten are stuffed, ive got one on my 4k and i had to bypass the factory ignitor and wire a bosch one and it works a treat, if ya need any wiring sorted, i will be able to help out caus in an auto electrican., if nearby i could have a look for ya. cheers, ash Report
October 24, 200817 yr Author comment_284200 ok sweet as, do you have photos of the wiring and stuff on your 4k, including the dizzy and the wires and stuff. and the wire that goes to oil sender and temp sender and whats the other for? cheers man but you are in qld i think and imin coffs harbour nsw and no other ke70 owners are around that i know of aye have a good one man Travis Report
October 24, 200817 yr comment_284206 i don't have a pic of the ign system but my setup has a coil of a vn commodore v8 and the ign modual is a bosh part no BIM024 and inside the dizzy were the old modual was i just cut it out and ran 2 wires to get rid of it, the 2 wires from the dizzy go striaght from the dizzy to the ign modual, the coil must have a 12v power feed to the positive then a positive and negative from the coil go to the modual all up the new modual is a 4 wire unit with a 12v feed negative feed to coil, and the 2 wires from the pickup out of the dizzy. but if yours is ok just run the 2 wires to the coil (it should be a black and a black with a orange trace) the black wire to negative and the other to the positive, and get rid of the old coil and ign ballast resistor to give a 12v feed to coil, any more just ask cheers, ash Report
October 24, 200817 yr Author comment_284211 i have a black with green writing 12v nippon denso electric dizzy coil. so the dizzy has 2 wires coming out of it: a red clay one. and a white one, which one to which part on the coil you reckon? cheers many, no anything about the altenator also? cheers Travis Report
