November 23, 200817 yr comment_292343 I'm about 2 get a cam re-grind for my 3k its got a 40doce weber sidedraft extractors and a 2" exhaust I'm thinking about getting a tighe cams 474, i want maximum lumpy idle as the car is only used on the weekends, has any one used this grind cam on the street? Report
November 27, 200817 yr comment_293459 nope, but i will be interested to see how it goes in terms of street drivability Report
November 27, 200817 yr comment_293488 hey, theres a ke70 on youtube with a MASS cam and i was talking to him, his was a custom grind but he said the 413 tighe cam was pretty close to his grind... Report
November 28, 200817 yr comment_293559 hey, theres a ke70 on youtube with a MASS cam and i was talking to him, his was a custom grind but he said the 413 tighe cam was pretty close to his grind... This is a lumpy cam!!!!! Matt Report
November 28, 200817 yr Author comment_293622 madrolla68 thats the sort cam i want!!!! what is that thing running??? Report
November 28, 200817 yr comment_293627 madrolla68 thats the sort cam i want!!!! what is that thing running??? The engine is a 5K, thats running 7.8:1 comp also so with bigger comp and carbies it sounds mad. Biggest Cosworth grind available. .420" Lift 50/86 316 degrees duration. MAtt Edited November 28, 200817 yr by madrolla68 Report
November 28, 200817 yr Author comment_293636 my mind is made up thanks to the input on this I'm going to go with a camtech cams CT003 615 should sound pretty mean thanks guys! Report
November 30, 200817 yr comment_294193 And a pig to drive to boot! Rough idle, strong top end, competition engines only. Min 12:1 comp ratio. I'm guessing your motor is definitely not a competition engine (or you'd be looking for a cam with the characteristics you want, not just a gay idle) and I'm 99.9999% certain you wont be running anywhere NEAR 12:1 compression ratio. I give it a month and you'll be looking for a stock cam. Report
November 30, 200817 yr comment_294206 And a pig to drive to boot! I'm guessing your motor is definitely not a competition engine (or you'd be looking for a cam with the characteristics you want, not just a gay idle) and I'm 99.9999% certain you wont be running anywhere NEAR 12:1 compression ratio. I give it a month and you'll be looking for a stock cam. I hope hes not just putting a big cam into a stock motor. Sure it will idle lumpy but thats about all. MAtt Report
December 1, 200817 yr comment_294367 I'm about 2 get a cam re-grind for my 3k its got a 40doce weber sidedraft extractors and a 2" exhaust I hope hes not just putting a big cam into a stock motor. Sure it will idle lumpy but thats about all. Certainly looks that way. Report
December 5, 200817 yr Author comment_295474 as i said my car is to only be used on the weekends all i want is a lumpy idle I'm not after a performance increase it is a 3k after all. if you guys know of a cam grind that offers maximum lumpy idle and is still streetable on around 9.5:1 compression let me know??? Report
December 5, 200817 yr comment_295524 as i said my car is to only be used on the weekends all i want is a lumpy idle I'm not after a performance increase it is a 3k after all. if you guys know of a cam grind that offers maximum lumpy idle and is still streetable on around 9.5:1 compression let me know??? Lighten flywheel, remove clutch fan and run something around 290 degrees duration. Should see some excellent lump while remaining streetable. Report
