punchy111 Posted February 20, 2009 Report Posted February 20, 2009 will i need to take out my windscreen to change the dash pad in my KE25? cos mine is f@$kED! and i need to change it bad before i accelerate and a chunck falls into my lap. cheers. Quote
mitch4397 Posted February 27, 2009 Report Posted February 27, 2009 will i need to take out my windscreen to change the dash pad in my KE25? cos mine is f@$kED! and i need to change it bad before i accelerate and a chunck falls into my lap. cheers. No you don't need too. I just re-did mine. There are screws that run along the inside of the dash that you can loosen to pry up the metal piece that holds the dash mat in. You'll need to remove the glove box completely to be able to get to the ones behind the instrument cluster. From memory there's about six. If you have no idea where these screws are, undo your air-vents on the sides and you can see them. To make it easy, get a small spanner that fits perfectly. Your around Mitcham area? I can give you a hand if you want. Mitch Quote
