hey guys I'm in the process of stripping the last stuff off my wreck and i want the doors and ignition barrel so my car has the same key for all... anyone able to tell me how to get it out?
considering a big hammer lol.
remove steering shroud,remove two phillips head screw at the bottom of the barrel,get a pin punch and a medium size hammer slowly tap anti clockwise the two flat looking screw heads or maybe tappered shape.make sure you make a pin punch mark to the top of the screw head so you can start from there.to install just reverse the procedure.hack saw the top of the flat screw so you just use a flat blade screw driver to tighten them back on.
hope this helps you and good luck!
Edited by drc_ke20
