April 24, 200917 yr comment_339228 Hey guys, i've recently bought a ke70 and have found out that it is only running on 3 cylinders... I changed the particular spark plug and tested that but it still wasnt firing from that cylinder, could it be the distribution lead? or maybe trouble in the particular cylinder? Feedback would be great thanks! Report
April 24, 200917 yr comment_339360 Check your rotor button or the contacts in the top of the dizzy cap for corosion build up or wear. clean or replace as required. Report
